9 years agoMaximum width of FIFO
Hello, The maximum width of a FIFO in the IP catalog GUI wizard is limited to 256 bits. I need a wider FIFO and want to avoid cascading FIFOs. Will it work to manually change the generat...
9 years ago --- Quote Start --- The maximum width of a FIFO in the IP catalog GUI wizard is limited to 256 bits. --- Quote End --- No it isn't. IP user guides say --- Quote Start --- Note that you can manually enter a number that is not in the drop-down list. --- Quote End ---
