9 years agoMaximum width of FIFO
Hello, The maximum width of a FIFO in the IP catalog GUI wizard is limited to 256 bits. I need a wider FIFO and want to avoid cascading FIFOs. Will it work to manually change the generat...
9 years agoDid you try it? what were the results?
Why not use two parrallel fifos?
