12 years agoHi Angela: That's really interesting. I only see the smaller Z devices with the 1.8V core.
I checked Quartus versions 12.0 -> 13.1 and none of the G variations came up in any of these versions. I also tried to change the core voltage to 1.8V in the device and pin options and that is also locked out. I haven't worked with this family much. So I don't know the why it would be missing from the standard devices lists. (I'm using the full licensed version of quartus, so it should be there).. I suggest you open a support case, or contact your FAE if no one else on this site is able to help. Usually as device support is dropped, it's listed on https://www.altera.com/download/sw/dnl-sw-index.jsp when you select by device. But Max II is still showing as fully supported. Pete
