MAX10 .sof and .pof programming problem - device remains tristate
First time using MAX10.
I have three LEDs connected, VHDL driving one low, one high and toggle third one.
- I do compile, .sof is generated. Run programmer and autodetect.
- Device is selected correctly as per hardware
- I program .sof with JTAG and it show successful, but LEDs remain in tristate
So I tried the autogenerated .pof file, but it just fails programming to CFM0 ( single image)
- to do this, I delete the .sof line in programmer and add the .pof file, it then shows the CFM0 and UFM.
- I tick the CFM0 for programming
- and click on start
DEV-OE pin is connected to GND
DEV-CLRn is floating
CONFIG_SEL = '1'
nConfig pulled to '1'
CONF_DONE and nSTATUS t oground via LED+resistor
In device pin options the following settings:
- no tickboxes enabled
- internal configuration
- single compressed image
- tickbox for "generate compressed bitstream" enabled
Any ideas welcome..
- YuanLi_S_Intel
Can you share me what is the error message you get when you are programming POF using quartus programmer?
Meanwhile for the SOF file, can you check if your LED is connecting to the correct pin in the VHDL? It should work once SOF file is able to program into it.
- Ivor
Actually, I have just sorted out the problem.
Both the nStatus and CONF_DONE lines were just going to GND via resistor and LED. So I pulled them up to Vcc via 10k and then after SOF programming, the device came out of tristate and the POF programming then also worked.
Thanks for the reponse though.
My next issue is that the elf download fails due to not being able to pause or reset NIOS. Is there a simple example design to use to check that it is not some other hardware problem?
- YuanLi_S_Intel
We have several design example for NIOS II on MAX 10. You may take a look at link below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/tt/tt_my_first_nios_sw.pdf
https://www.intel.com/content/dam/altera-www/global/en_US/uploads/4/4f/Hello_world_LCD_tutorial.pdf
You may find more design example at link below:
https://fpgacloud.intel.com/devstore/
If you have further question on NIOS, i would suggest you to create another thread in NIOS II category so that our NIOS expert in the community is able to assist.
Bruce
