Ivor
5 years agoMAX10 .sof and .pof programming problem - device remains tristate
First time using MAX10.
I have three LEDs connected, VHDL driving one low, one high and toggle third one.
I do compile, .sof is generated. Run programmer and autodetect.
Device is selected c...
YuanLi_S_Intel
5 years agoCan you share me what is the error message you get when you are programming POF using quartus programmer?
Meanwhile for the SOF file, can you check if your LED is connecting to the correct pin in the VHDL? It should work once SOF file is able to program into it.
