MAX II
May I know why you want to change the temperature and voltage?
The valid operating conditions available for MAX II EPM2210F256I5 device is 5_slow and MIN_fast.
The slow vs fast simply means the slowest and fastest conditions for that speed grade, which is speed grade 5 for EPM2210F256I5 device.
As long as both the timing corner (slowest and fastest) is met, then you are good to go.
Richard Tan
- mouwei2 years ago
Hello, I need to do static time series analysis under three working conditions (maximum working condition, minimum working condition and typical working condition), in which the maximum working condition is the highest temperature and the lowest voltage; The minimum operating condition is the lowest temperature and the highest voltage. Typical operating conditions are normal temperature and normal voltage. Therefore, I would like to know how quartus II13.1 changes the voltage and temperature conditions for MAX II series chip EPM2210F256I5 to simulate these three environments
- mouwei2 years ago
I use quartus II13.1 version to conduct static timing analysis on the Cyclone series of chips. The software will come with several operating conditions, such as the Slow 1200mV 85C Model and Slow 1200mV 0C Model, in which voltage and temperature values are defined. But I use the MAX II series chip EPM2210F256I5 only 5_slow and MIN_fast two, is the chip does not support static timing analysis under different temperatures and voltages? May I ask whether quaruts II13.1 can customize temperature and voltage for static time series analysis?
