17 years agoIf it is truly an asynchronous reset, then why would you try and constrain the delay from the input port to the register(s)? Normally this would be cut with a set_false_path constraint. If you can relate it to the latch clock of the register somehow, e.g. with a virtual launch clock, then you can use a set_max_delay constraint to constrain it (but then it wouldn't be a truly asynchronous reset). In the next Quartus II release, 8.1, there is a new set_net_delay command that should do what you want to do if you can wait until then.
