Hi Tricky, thank you for your reply.
The reason I said that there are fractions is because when I divide the 2 32bit integers I will probably get a fraction.
You mean that I should convert the 32bit integers to ufixed and then divide them and store the answer in a 64bit ufixed signal? I tried to do that but I got a strange error regarding the "/" operator, that's why I used the lpm_divide megafunction instead, which works for std_logic_vector.
If I'm not using the std_logic_unsigned package I get an error even for a "+" sign, where am I wrong? Have I included all the correct files from the fixed-point package?
