Master qsf file
Hello forum, I am new to the Quartus software. I have written the code and it is working fine. I had to interface the Altera Cyclone 4 EP4CE22F17C6N. Where do I find the master qsf file for this board (so as to link the pins to the inputs and outputs) ?
Thanks in Advance
Pramod
May I know which dev kit board are you using? After that, only then can I search for the board's User Manual that includes the pin assignments you're looking for.
For example, if you're using DE0-Nano Board which contains a Cyclone IV E FPGA, you may refer to pin assignments as stated in the user manual: https://www.farnell.com/datasheets/2283623.pdf
You may check out the forum below to learn more about the board pin assignment: https://community.intel.com/t5/Intel-Quartus-Prime-Software/DE-series-board-pin-assignment-for-Cyclone-10/m-p/649368
Ven Ting
- sstrell
What board? Are you talking about a dev kit? You can usually download example designs with these assignments created for specific dev kits. Otherwise, you'll need to use the Pin Planner to manually set the correct I/O locations and other related assignments.
- VenT_Altera
Ven Ting
- Pramod_Krishna
Thank you
- VenT_Altera
May I know any updates from you?
Ven Ting
- VenT_Altera
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions. Thanks.
Ven Ting
p/s: If any answer from the community or Intel Support are helpful, please feel free to give best answer or rate 9/10 survey
