Pramod_Krishna
4 years agoMaster qsf file
Hello forum, I am new to the Quartus software. I have written the code and it is working fine. I had to interface the Altera Cyclone 4 EP4CE22F17C6N. Where do I find the master qsf file for this boar...
- 4 years ago
May I know which dev kit board are you using? After that, only then can I search for the board's User Manual that includes the pin assignments you're looking for.
For example, if you're using DE0-Nano Board which contains a Cyclone IV E FPGA, you may refer to pin assignments as stated in the user manual: https://www.farnell.com/datasheets/2283623.pdf
You may check out the forum below to learn more about the board pin assignment: https://community.intel.com/t5/Intel-Quartus-Prime-Software/DE-series-board-pin-assignment-for-Cyclone-10/m-p/649368
Ven Ting
VenT_Altera
4 years agoHi,
May I know any updates from you?
Ven Ting
