Making custom component visible to Platform Designer (Qsys)
You don't mention any error messages or any other info about why your components aren't showing up in the IP Catalog, but my guess is that the connection between the _hw.tcl file and your custom component HDL code is getting lost. This can happen if you use the Platform Designer Component Editor and then move the _hw.tcl file from the project directory and/or the HDL code.
In recent versions of Platform Designer (probably within the last 3-4 years), the _hw.tcl file from the Component Editor always gets created at the location of the .qsys file, not at the location of the HDL code you point to in the Component Editor, which is what it used to do. As such, if you move either the _hw.tcl or the HDL code, even if you point PD to the location of the _hw.tcl, it won't work.
What you have to do is edit the _hw.tcl file, wherever you've moved it to and edit the following:
add_fileset_file <file>.[v|vhd] [VERILOG|VHDL] PATH <file_path> [TOP_LEVEL_FILE]
If you set the path correctly and then refresh PD (F5 key or menu command), it should work.
Hello @sstrell ,
Thank you very much for your response and sorry for delay.
You are right that initially we use Platform Designer Component Editor to create _hw.tcl file and then are moving it to other location. But we are moving RTL files along with _hw.tcl file. And hence, RELATIVE path remains same.
In our case, we are used to place RTL files in hdl folder and _hw.tcl file remains in same folder in which hdl folder resides. Then, we are using following commands to add files.
add_fileset_file ./sls_i2c_mstr/i2cc_wrapper.sv SYSTEM_VERILOG PATH ./hdl/i2cc_wrapper.sv TOP_LEVEL_FILE add_fileset_file ./sls_i2c_mstr/i2cc_user_define.pkg.sv SYSTEM_VERILOG PATH ./hdl/i2cc_user_define.pkg.sv add_fileset_file ./sls_i2c_mstr/i2cc_dp_ram_mf.v VERILOG PATH ./hdl/i2cc_dp_ram_mf.v
Do you see any issue in this?
Thank you and Have a Nice Day!
Bhaumik
- sstrell5 years ago
Try an absolute path instead of a relative path. I think the issue may be that the relative path is relative to the .qsys file, not relative to the _hw.tcl file.
- BDarji5 years ago
Hello @sstrell ,
Thank you for your response and continuous support.
I do not think that relative path is an issue here because of following reasons:
(1) Please refer following image. It states we can either use absolute or relative path.
(2) Note that if we use 'user_component.ipx' file method I described in initial post, there is no issue. RTL files are generated properly when Qsys system is generated. Hence, I think file path is fine.
What do you think?
Have a Nice Day!
Kind Regards,
Bhaumik
Have you tried the absolute path? This may be a bug that does not follow the documentation. I've seen it happen.
Your .ipx solution is fine, but it's extra work you shouldn't have to do to make the IP visible.
