13 years ago
Making a process
Hello
A B C F(A,B,C)
0 0 0      0
0 0 1        1
0 1 0      1
0 1 1      1
1 0 0      1
1 0 1      0
1 1 0      0
1 1 1      1
With the truth table above,how can I make a process?
A,B,C need to be a vector
ABC are the in ports
F is the out port
thanks!
    --- Quote Start ---
    LIKE this?
    entity tabelaverdades is
    Port ( D : in BIT_VECTOR(2 DOWNTO 0);
    F : out BIT);
    end tabelaverdades;
    --- Quote End ---
    Sorry, I thought you mean A, B, C, and F were bit_vectors.
    In the function above the statement (A & B & C) is converting the three inputs to a 3-element vector, i.e., its equivalent to your D input.
    However, as Kaz comments, you need to check the order, i.e., D <= A & B & C, or D <= C & B & A.
    Cheers,
    Dave
    --- Quote Start ---
    the F <= D(0) or D(1) or D(2); is for what?
    thanks
    --- Quote End ---
    The or takes care of all the possible results except D = 110 or 101 which is then updated to 0 e.g.
    or of 000 = 0
    or of 111 = 1
    or of 110 = 1 then forced to 0 and so on
    Normally compiler will take care of optimising logic but you can help it.
    I mean you can use case statement and leave it to tool
    case D is
    when "000" => F <= '0';
    when "001" => F <= '1';
    My code:
               F : out  BIT);
    end tabelaverdades;
    architecture tabelaverdades_arq of tabelaverdades is
    begin
    cnt:process(D)
    begin
    D <= A & B & C;
    case D is
    when "010" => F <= '1';
    when "011" => F <= '1';
    when "100" => F <= '1';
    when "101" => F <= '0';
    when "110" => F <= '0';
    when "111" => F <= '1';
    end case;
    end process cnt;
    end tabelaverdades_arq;
    is good?
    OK but you don't have A,B,C defined(they are just truth table concept).
    here is another way:
    case D is
    when "000" | "101" | "110" => F <= '0';
    when others => F <= '1';
    end case;
    Don't use A,B,C at all as input is D and it wouldn't compile. You need to work out mentally how to map A,B,C of table to bit index of D then only use D in your code.
    --- Quote Start ---
    ok,now How can I make a benchtest?
    --- Quote End ---
    I have been thinking about a test bench for the truth table being discussed in this post. I have developed the following VHDL code to test the logic:
    library ieee;
    use ieee.std_logic_1164.all;
    entity testxx is
    end entity;
    architecture arch of testxx is
    function to_string(sv: Std_Logic_Vector) return string is
    use Std.TextIO.all;
    variable bv: bit_vector(sv'range) := to_bitvector(sv);
    variable lp: line;
    begin
    write(lp, bv);
    return lp.all;
    end;
    component truthtable is
    port(in_a: in std_logic;
    in_b: in std_logic;
    in_c: in std_logic;
    out_f: out std_logic);
    end component;
    type tvector is array (7 downto 0)
    of std_logic_vector(3 downto 0);
    constant test_vectors: tvector := ("0000",
    "0011",
    -- "0101", -- This is correct
    "0100", -- This is an error
    "0111",
    "1001",
    "1010",
    "1100",
    "1111");
    signal a,b,c,z_expected: std_logic;
    signal z : std_logic;
    signal test: std_logic_vector(3 downto 0);
    begin
    table1:truthtable port map(in_a => a, in_b => b, in_c => c, out_f => z);
    process
    begin
    for i in 7 downto 0 loop
    test <= test_vectors(i);
    a <= test_vectors(i)(3);
    b <= test_vectors(i)(2);
    c <= test_vectors(i)(1);
    z_expected <= test_vectors(i)(0);
    wait for 10 ns;
    if (z = not z_expected) then
    report "vector=" & to_string(test);
    report "z_expected = " & Std_Logic'image(z_expected) & " z = " & Std_Logic'image(z);
    end if;
    end loop;
    wait;
    end process;
    end architecture;
    I would be interested in any comment anyone has on the above test bench.
    J :)
