--- Quote Start ---
ok,now How can I make a benchtest?
--- Quote End ---
I have been thinking about a test bench for the truth table being discussed in this post. I have developed the following VHDL code to test the logic:
library ieee;
use ieee.std_logic_1164.all;
entity testxx is
end entity;
architecture arch of testxx is
function to_string(sv: Std_Logic_Vector) return string is
use Std.TextIO.all;
variable bv: bit_vector(sv'range) := to_bitvector(sv);
variable lp: line;
begin
write(lp, bv);
return lp.all;
end;
component truthtable is
port(in_a: in std_logic;
in_b: in std_logic;
in_c: in std_logic;
out_f: out std_logic);
end component;
type tvector is array (7 downto 0)
of std_logic_vector(3 downto 0);
constant test_vectors: tvector := ("0000",
"0011",
-- "0101", -- This is correct
"0100", -- This is an error
"0111",
"1001",
"1010",
"1100",
"1111");
signal a,b,c,z_expected: std_logic;
signal z : std_logic;
signal test: std_logic_vector(3 downto 0);
begin
table1:truthtable port map(in_a => a, in_b => b, in_c => c, out_f => z);
process
begin
for i in 7 downto 0 loop
test <= test_vectors(i);
a <= test_vectors(i)(3);
b <= test_vectors(i)(2);
c <= test_vectors(i)(1);
z_expected <= test_vectors(i)(0);
wait for 10 ns;
if (z = not z_expected) then
report "vector=" & to_string(test);
report "z_expected = " & Std_Logic'image(z_expected) & " z = " & Std_Logic'image(z);
end if;
end loop;
wait;
end process;
end architecture;
I would be interested in any comment anyone has on the above test bench.
J :)
