13 years agoSo would this be correct?
library ieee;
use ieee.std_logic_1164.all;
library altera_mf;
use altera_mf.all;
entity hello_tta_altera_onchip_ram_comp is
generic (
init_file_g : string := "init_data.mif";
dev_family_g : string := "Cyclone II";
addrw_g : integer := 10;
dataw_g : integer := 32
port (
address : in std_logic_vector (addrw_g-1 downto 0);
byteena : in std_logic_vector (dataw_g/8-1 downto 0);
clken : in std_logic;
clock : in std_logic;
data : in std_logic_vector (dataw_g-1 downto 0);
wren : in std_logic;
q : out std_logic_vector (dataw_g-1 downto 0)
end hello_tta_altera_onchip_ram_comp;
architecture SYN of hello_tta_altera_onchip_ram_comp is
signal sub_wireH, sub_wireL : std_logic_vector (dataw_g-1 downto 0);
signal clk_enH, clk_enL: std_logic;
constant byte_size_c : integer := 8;
constant bew_c : integer := dataw_g/byte_size_c;
constant widthad_a_in: integer := addrw_g-1;
component altsyncram
generic (
byte_size : natural;
clock_enable_input_a : string;
clock_enable_output_a : string;
init_file : string;
intended_device_family : string;
lpm_hint : string;
lpm_type : string;
numwords_a : natural;
operation_mode : string;
outdata_aclr_a : string;
outdata_reg_a : string;
power_up_uninitialized : string;
widthad_a : natural;
width_a : natural;
ram_block_type : string;
width_byteena_a : natural
port (
clocken0 : in std_logic;
wren_a : in std_logic;
clock0 : in std_logic;
byteena_a : in std_logic_vector (bew_c-1 downto 0);
address_a : in std_logic_vector (addrw_g-2 downto 0);
q_a : out std_logic_vector (dataw_g-1 downto 0);
data_a : in std_logic_vector (dataw_g-1 downto 0)
end component;
begin
with clk_enH select q <= sub_wireH when '1', sub_wireL when '0';
--q <= sub_wireH(dataw_g-1 downto 0) WHEN clk_enH = '1' ELSE
-- sub_wireL(dataw_g-1 downto 0);
clk_enH <= clken and address(addrw_g-1);
clk_enL <= clken and not address(addrw_g-1);
altsyncram_component_high : altsyncram
generic map (
byte_size => byte_size_c,
clock_enable_input_a => "NORMAL",
clock_enable_output_a => "BYPASS",
intended_device_family => dev_family_g,
init_file => "UNUSED",
lpm_hint => "ENABLE_RUNTIME_MOD=NO",
lpm_type => "altsyncram",
numwords_a => 2**widthad_a_in,
operation_mode => "SINGLE_PORT",
outdata_aclr_a => "NONE",
outdata_reg_a => "UNREGISTERED",
power_up_uninitialized => "FALSE",
ram_block_type => "M9K",
widthad_a => widthad_a_in,
width_a => dataw_g,
width_byteena_a => bew_c
port map (
clocken0 => clk_enH,
wren_a => wren,
clock0 => clock,
byteena_a => byteena,
address_a => address(addrw_g-2 downto 0),
data_a => data,
q_a => sub_wireH
altysyncram_component_low: altsyncram
generic map(
init_file => init_file_g,
intended_device_family =>dev_family_g,
ram_block_type => "M144K",
width_a => dataw_g,
port map (
clocken0 => clk_enL,
wren_a => wren,
clock0 => clock,
data_a => data,
q_a => sub_wireL
end SYN;
The initialization file had nothing beyond the address 49242, so i did not initialize higher side of memory.
