13 years agoI use VHDL code to instantiate altsyncram. Here is the code for the data RAM.
library ieee;
use ieee.std_logic_1164.all;
library altera_mf;
use altera_mf.all;
entity tta_altera_onchip_ram_comp is
generic (
init_file_g : string := "init_data.mif";
dev_family_g : string := "Cyclone II";
addrw_g : integer := 10;
dataw_g : integer := 32
port (
address : in std_logic_vector (addrw_g-1 downto 0);
byteena : in std_logic_vector (dataw_g/8-1 downto 0);
clken : in std_logic;
clock : in std_logic;
data : in std_logic_vector (dataw_g-1 downto 0);
wren : in std_logic;
q : out std_logic_vector (dataw_g-1 downto 0)
end tta_altera_onchip_ram_comp;
architecture SYN of tta_altera_onchip_ram_comp is
signal sub_wire0 : std_logic_vector (dataw_g-1 downto 0);
constant byte_size_c : integer := 8;
constant bew_c : integer := dataw_g/byte_size_c;
component altsyncram
generic (
byte_size : natural;
clock_enable_input_a : string;
clock_enable_output_a : string;
init_file : string;
intended_device_family : string;
lpm_hint : string;
lpm_type : string;
numwords_a : natural;
operation_mode : string;
outdata_aclr_a : string;
outdata_reg_a : string;
power_up_uninitialized : string;
widthad_a : natural;
width_a : natural;
ram_block_type : string;
width_byteena_a : natural
port (
clocken0 : in std_logic;
wren_a : in std_logic;
clock0 : in std_logic;
byteena_a : in std_logic_vector (bew_c-1 downto 0);
address_a : in std_logic_vector (addrw_g-1 downto 0);
q_a : out std_logic_vector (dataw_g-1 downto 0);
data_a : in std_logic_vector (dataw_g-1 downto 0)
end component;
begin
q <= sub_wire0(dataw_g-1 downto 0);
altsyncram_component : altsyncram
generic map (
byte_size => byte_size_c,
clock_enable_input_a => "NORMAL",
clock_enable_output_a => "BYPASS",
init_file => init_file_g,
intended_device_family => dev_family_g,
lpm_hint => "ENABLE_RUNTIME_MOD=NO",
lpm_type => "altsyncram",
numwords_a => 2**addrw_g,
operation_mode => "SINGLE_PORT",
outdata_aclr_a => "NONE",
outdata_reg_a => "UNREGISTERED",
power_up_uninitialized => "FALSE",
ram_block_type => "Auto",
widthad_a => addrw_g,
width_a => dataw_g,
width_byteena_a => bew_c
port map (
clocken0 => clken,
wren_a => wren,
clock0 => clock,
byteena_a => byteena,
address_a => address,
data_a => data,
q_a => sub_wire0
end SYN;
And here is the code for code ROM
library ieee;
library altera_mf;
use altera_mf.all;
entity tta_altera_onchip_rom_comp is
generic (
dataw_g : integer := 32);
port (
q : out std_logic_vector (dataw_g-1 downto 0));
end tta_altera_onchip_rom_comp;
architecture SYN of tta_altera_onchip_rom_comp is
generic (
init_file : string;
lpm_hint : string;
lpm_type : string;
width_a : natural;
port (
end component;
begin
generic map (
operation_mode => "ROM",
width_a => dataw_g,
width_byteena_a => 1
port map (
clocken0 => clken,
clock0 => clock,
q_a => sub_wire0
end SYN;
I have set ram_block_type to "M9K" and "M144K" as well and have tried it. But my intention is to synthesize data RAM with both "M9K" and "M144K". The sizes of data RAM and code ROM is mentioned in above post. The option "Auto" takes only M144K for data RAM and M9K for code ROM. Is it possible to use both M144K and remaining of M9K blocks for data RAM?
