David_MD_KIM's avatar
David_MD_KIM
7 years ago
LVDS PIN define and ALT_input_diff error
I define IO PIN and I use ALT_INBUF_DIFF
After compile error message as below;
Error (275021): Illegal wire or bus name "CAM_CP(n)" of type pin
How fix this problem?
David
  • Vicky1's avatar
    Vicky1
    I am not clear whether you get this Error in rtl or after pin planner.
    I would like to suggest you check the below details,
    https://forums.intel.com/s/question/0D50P00003yyNpESAU/altinbufdiff-and-pin-planner
    In pin planner, assign the pin only to the positive pin of a differential pair, (n) pin will get assigned automatically by tool.
    Refer the 'Assigning Differential Pins 'from link below,
    https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii52013.pdf
    Vicky
    • David_MD_KIM's avatar
      David_MD_KIM
      Hi, Thanks for your email. However I try very simple case as attached. But It is same error result. Please advice . Thanks David
  • Vicky1's avatar
    Vicky1
    Hi David,
    'However I try very simple case as attached.' - - - - where?
    could you please provide the project(*.qar) file (Project menu->Archive Project..) for replication purpose?
    Vicky
      • Vicky1's avatar
        Vicky1
        Hi David,
        I am unable to see your capture files, Can you?
        'could you please provide the project(*.qar) file (Project menu->Archive Project..) for replication purpose?' ------ if possible.
        Vicky
  • Vicky1's avatar
    Vicky1
    Hi David,
    would you like to provide files or should I consider that case to be closed?
    Vicky
