David_MD_KIM
7 years agoLVDS PIN define and ALT_input_diff error
I define IO PIN and I use ALT_INBUF_DIFF After compile error message as below; Error (275021): Illegal wire or bus name "CAM_CP(n)" of type pin How fix this problem? Thanks David
Vicky1
7 years agoHi,
I am not clear whether you get this Error in rtl or after pin planner.
I would like to suggest you check the below details,
https://forums.intel.com/s/question/0D50P00003yyNpESAU/altinbufdiff-and-pin-planner
In pin planner, assign the pin only to the positive pin of a differential pair, (n) pin will get assigned automatically by tool.
Refer the 'Assigning Differential Pins 'from link below,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qts_qii52013.pdf
Vicky
David_MD_KIM
7 years agoHi,
Thanks for your email.
However I try very simple case as attached.
But It is same error result.
Please advice .
David
