10 years agoLVDS Differential IO pin Mapping error
HI I have tried mapping Differential IO signals ADC_P to PIN_A29 and ADC_N to PIN_A28 using Tcl script In Quartus II 12.0 version. In tool Its automatically creating a differential pair for A...
10 years agoIf you really want the signal names ADC_p and ADC_n instead of the tool's auto generated (n) name use this process. It is a workaround I
use. It is a pain :-( 1) Change all I/O standards for p and n to 2.5V 2) Assign the single ended p and n on to the diff pin pair you want to use on the pin planner 3) Change them one by one to LVDS_3_R standard and change their diff pair partner e.g. assign data_p[0] to Y6, assign data_n[0] to Y5. Change data_p[0] to LVDS_3_R. next change the complementary signal in the pin planner ‘Differential pair ‘ column from data_p[0](n) to data_n[0] and then press ‘enter’ it will ask you if you want to change data_n[0] to LVDS_3_R. Click yes That’s one done, each one has to be done individually
