15 years agoi think you can take the instantiation of the lpm function out of the generated HDL that you edited, and use that component declaration and instantiation in your own HDL. you can probably even change parameters, just make sure they are legal since this is normally taken care of by the wizard.
you'll probably spend more time than you'd like writing HDL that will do the same as the MegaWizard (as far as performance and resource usage are concerned)
