15 years ago --- Quote Start --- after you generate your multiplier go into the .vhd and change the pipeline from 2 to 3. based on the fmax it seems like it took properly completely unrelated, i'd advise you to change your forum username, you might be a spam target with your email out in the open like that --- Quote End --- That worked. Thanks. Two related questions. Is there any way I can encourage inference of the structure I want, or am I stuck with the MegaWizard? How do I change my username (I poked around and couldn't find any obvious way)? Thanks Pete
