14 years agolpm_latch makes quartus_map run much longer
I am integrating a netlist design which has about 40K latches with async clear or set.
If I use LPM_LATCH for these latches then quartus takes very long to map. If I use simple LATCH but pull the async ctrls to the D and ENA pins then it finishes much faster. Obviously i would like to use the lpm_latch but I don;t know how to make the tool run fast. Please give some pointers.. I am using stratix iv and quartus 11.
