16 years agothanks for making it clear about Fifo synthesis and fitter replacements.
--- Quote Start --- what means connected with a bus? If the FIFO output is influencing output signals indirectly through the bus, the FIFO is synthesized. --- Quote End --- I will drag a bus line from q[7..0] and name it FifoDout[7..0] and connect it it input of another module. Logically, fitter should be able to produce LEs for this connection. Unfortunately not. Which is my problem that needs to be resolved
