12 years agolpm_add_sub synthesis error on Q2 9.0 SP2
Hi
I am using lpm_add_sub in ACEX1K EP1K50TC144-1 and I am getting this warning during synthesis process. I am using Q2 9.0 SP2 due to ACEX1K device support. Warning: Ignored 6 CARRY_SUM primitives -- cannot place fan-in logic in single logic cell Warning: Can't place logic feeding CARRY_SUM primitive "abs3:$00041|lpm_add_sub:$00002|addcore:adder1_0[0]|a_csnbuffer:result_node|cs_buffer[3]" in single logic cell Warning: Node "abs3:$00041|lpm_abs:$00000|lcarry[12]" of type CARRY_SUM Warning: Node "abs3:$00041|lpm_add_sub:$00002|addcore:adder1_0[0]|a_csnbuffer:result_node|cs_buffer[2]" of type CARRY_SUM .. .. Basically the lpm_add_sub was not successfully implemented in the design and the functional simulation fails as well. I can get rid of this warning by ticking the "ignore carry buffer" in the synthesis option but the fmax seems to suffers. Ahdl code calling lpm_add_sub as below (abs_diff[], , /over_max) = lpm_add_sub ( , abs_in[], limit[],gnd,h1,, ) WITH (LPM_WIDTH = 14, LPM_PIPELINE=2, LPM_REPRESENTATION="unsigned"); anybody know why I have to enable "ignore carry buffer" to get this to work? it seems strange for altera's lpm function to have this issue Thanks Alan
