18 years agoThe main three stages of fit time, placement, routing and physical synthesis(if on), all give messages in the .fit.rpt for how long they took, so these are worth comparing. Also compare the device resources being used. Note that Design Compiler is an ASIC tool. I believe they have a companion tool called FPGA Compiler, but I'm not sure if that's still available.
