17 years ago --- Quote Start --- i am kind of new with logic lock and logic partitions, what i would do is to create an estiamted floorplan of the final design with logic partitions and then use logic lock for the instances with the combinatorial logic. What do you think??? Thanks for your reply juan --- Quote End --- Hi Juan, I would start with a run without any design partition or LogicLock Region, in order to get values for the size of the design parts. Keep in mind that when using design partitons your device utilization will increase, because partiton boundaries are fixed. No logic optimization will take place through partitions. How is your device utilization after a simple P&R run ? Kind regards GPK
