15 years agoHi
The lower level project has the assigned logiclock regions (as assigned in the top level project). So, there is no conflict between logiclock regions in the low and top level projects. I imported .qxf file. The version of the quartus is 9.1.   The only warning that I have which may be related to this issue is: Warning: Ignored routing constraints for partitions preserving relative placement to moved LogicLock regions Warning: Ignored routing constraints for partition "the name of the partition" Warning: Ignored routing constraints for partition "the name of the partition"
