BSuma's avatar
BSuma
5 years ago
localparam and parameter values in Synthesis report
I am writing a parameterized Verilog module. In the module I calculate some localparam values using the parameter valued passed. Please seed the code below for example. I want to know the values calculated for localparam during synthesis. But I cannot find that information in reports shown in the Quartus Prime software. I am using Quartus Prime Lite edition.
Where can I find that information?
module Counter #(CLOCK_FREQUENCY=25000000,TIME=1000000)(
input Clk,
input Start,
output reg End
localparam megs = (CLOCK_FREQUENCY/1000000)*TIME;
  • cblixt1's avatar
    cblixt1
    This is an old thread, but I found it because I have the same question. I may have a large number of localparams in a verilog module with complicated expressions. I would like to ensure that all of them are calculated as I expect, that I got operator precedence, rounding and such right.
    Now since Quartus calculates all these localparams at some point, it would be very useful to be able to see the result in a report. I tried Parameter Settings by Entity Instance, but it only shows parameters, not localparams.
    I would really not have to set up a simulation just to be able to see values that are already computed. Is there a way to see them? Would changing them from localparams to parameters (temporarily) do the trick?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
    KhaiY
    KhaiChein_Y_Intel
    You may check the parameter value in Processing > Compilation Report > Synthesis > Parameter Settings by Entity Instance > Parameter Settings for XX.
    KhaiY
    • BSuma's avatar
      BSuma
      No, I didn't try to simulate it.
      But, the code synthesizes and works when programmed to an FPGA chip.
