8 years agolocal memory bank
I have read best practice guide, but I am still confused. I have optimize the local memory to 1 read and 1 write. However, the report.html report that the"w_local" memory use 64 RAM blocks. ...
8 years agoI have also modified the code, but the RAM blocks usage become even worse larger than 64.
typedef struct{
short ff;
} filter_trans;
typedef struct{
filter_trans ww;
} data_trans;
typedef struct{
filter_trans ww;
} weight_trans;
__kernel(){
short __attribute__((numbanks(16),bankwidth(2))) w_local;
data_trans data_in = read_channel_intel(data_ch);
cont control = read_channel_intel(cont_ch);
weight_trans get_w;
# pragma unroll
for(int n=0; n<4; n++){
# pragma unroll
for(int j=0; j<16; j++){
get.ww.ff = w_local;
# pragma unroll
winograd = 0;
# pragma unroll
winograd += get_w.ww.ff * data_in.ww.ff;
Private memory Optimal Total replication 1 Number of banks 16 (banked on lowest dimension) Bank depth 16384 words Additional information Requested size 294912 bytes, implemented size 524288 bytes, stall-free, 16 reads and 16 writes. Banked on lowest dimension into 16 separate banks. Reducing accesses to exactly one read and one write for all on-chip memory systems may increase overall system performance. See Best Practices Guide : Local Memory for more information. Implemented size 524288 bytes Bank width 16 bits Requested size 294912 bytes Private memory implemented in on-chip block RAM.
