12 years ago
Load a .pof in flash using PFL in command line
I'd like to program my flash using a .pof file and the parallel flash loader as described here in the application note : AN478
This is working, and I'd like to do the same in command line (only the programmer part). By the way, is it possible to see what is executed in quartus gui ?
My tries with quartus_pgm are ok but I don't manage to "attach flash device" with my .pof file ...
I also did some experiments with nios flash programmer but it only accepts sof file and I need to use my .pof file which is encrypted !
Thanks for your help!
    I had a similar problem. Check that the Flash reset pin is not resetting the flash memory device.
    Thanks for your help bill-now.
    What do you mean by "flash reset pin" ?
    The pin in my Parallel Flash Loader (PFL) design ? or on the board ?
    I meant the pin on the Flash memory device. In my case this pin was controlled by the PFL and laso a microprocessor that used the Flash as its program memory after the PFL configured the FPGA.
