Thanks for your reply. I have extracted the relevant daemons from 7.1 but the situation has not change except the V9.2 now read V9.5.
The following is the output of debug log:
14:29:38 (lmgrd) -----------------------------------------------
14:29:38 (lmgrd) Please Note:
14:29:38 (lmgrd)
14:29:38 (lmgrd) This log is intended for debug purposes only.
14:29:38 (lmgrd) There are many details in licensing policies
14:29:38 (lmgrd) that are not reported in the information logged
14:29:38 (lmgrd) here, so if you use this log file for any kind
14:29:38 (lmgrd) of usage reporting you will generally produce
14:29:38 (lmgrd) incorrect results.
14:29:38 (lmgrd)
14:29:38 (lmgrd)
14:29:38 (lmgrd)
14:29:38 (lmgrd) Done rereading
14:29:38 (lmgrd) FLEXlm (v9.50) started on LECPC403 (IBM PC) (5/17/2007)
14:29:38 (lmgrd) Copyright (c) 1988-2004 by Macrovision Corporation. All rights reserved.
14:29:38 (lmgrd) US Patents 5,390,297 and 5,671,412.
14:29:38 (lmgrd) World Wide Web:
http://www.macrovision.com 14:29:38 (lmgrd) License file(s):
C:\Altera\Alteralic5April.dat 14:29:38 (lmgrd) lmgrd tcp-port 1800
14:29:38 (lmgrd) Starting vendor daemons ...
14:29:38 (lmgrd) Started alterad (pid 1608)
14:29:38 (lmgrd) alterad using TCP-port 4723
-jul-2038
14:29:38 (alterad) Warning: maxplus2 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0012 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0014 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0055 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00A7 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00A8 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00A4 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_0034 expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00AC expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00AD expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00BE expires 31-jul-2038
14:29:38 (alterad) Warning: 6AF7_00BF expires 31-jul-2038
14:29:38 (alterad) Warning: maxplus2verilog expires 31-jul-2038
14:29:38 (alterad) Warning: maxplus2vhdl expires 31-jul-2038
14:29:38 (alterad) Server started on LECPC403
Will try rebooting in a while but I am not giving much hope
