11 years agoQuestion 1:
Is is possible to select one of the comboBox options with dashboard_set_property? Example:
dashboard_set_property ${::led_control::dash_path} box_led_1 options { "Off" "On" "Mode 1" "Mode 2"}
dashboard_set_property ${::led_control::dash_path} box_led_2 options { "Off" "On" "Mode 1" "Mode 2"}
dashboard_set_property ${::led_control::dash_path} box_led_3 options { "Off" "On" "Mode 1" "Mode 2"}
dashboard_set_property ${::led_control::dash_path} box_led_4 options { "Off" "On" "Mode 1" "Mode 2"}
The first comboBox I would like to select not "Off" as default but "Mode 1" for example. Code below is not working.
dashboard_set_property ${::led_control::dash_path} box_led_1 select 2
Question 2:
proc add_led_control_component { led } {
dashboard_add ${::led_control::dash_path} label_led_${led} label leds_group
dashboard_set_property ${::led_control::dash_path} label_led_${led} text "Led ${led}"
dashboard_add ${::led_control::dash_path} box_led_${led} comboBox leds_group
dashboard_set_property ${::led_control::dash_path} box_led_${led} options { "Off" "On" "Blink fast" "Blink slow"}
dashboard_set_property ${::led_control::dash_path} box_led_${led} onChange {::led_control::toggle ${led}}
If I call the above proc with: ::led_control::add_led_control_component 1 The comboBox is added to my dashboard. But dashboard_set_property ${::led_control::dash_path} box_led_${led} onChange {::led_control::toggle ${led}} is not working good. Probably due to lack of TCL knowledge. See the error below.
SEVERE: java.lang.Exception: can't read "led": no such variable
while executing
"::led_control::toggle ${led}"
java.util.concurrent.ExecutionException: java.lang.Exception: can't read "led": no such variable
while executing
The proc arg led is not working as I expected. How can I fix this issue?
