WFH
New Member
18 hours agoLisence issue when running .do script
I am a beginner using the Questa FPGA starter edition for practicing SystemVerilog coding.
I downloaded the 2025.2 Version and obtained the fix lisence according to NIC ID (my PC's Ethernet adapter's MAC address). And I set accordingly the environment variable(LM_LICENSE_FILE and SALT_LICENSE_SERVER) pointing to the .dat file. The software Questa run successfully.
But when I want to use a .do script to run a simple SV simulation, the process failed and showed as attachment 1.
The programm is simple and I believe it has no advanced grammar (attachment 2 and 3), but it still failed.
Is that the limination of Starter Edition or problem about lisencing?
Thank you in advance.
