License file not recognized for questasim - Quartus 22.1.1 on Ubuntu 18.04
I have some trouble with my license Questasim generated by SSLC.
I use last version for linux (Quartus and Questa 22.1.1) .
I set up my license variable LM_LICENSE_FILE correctly but when I try to lunch ./vsim (questa) on terminal I have an error message, or when I try to lunch license setup on Quartus, nothing is recognized.
I really have many issues to implement my architecture using linux and Quartus.
Thank you,
Dorian
- AR_A_Intel
Hello
Welcome to Intel forum. But before setting up Questa, would you kindly help check, whether your machine is supported or not (OS) by referring to link below:
https://www.altera.com/support/support-resources/download/os-support.html
after that could you help re-confirm the Questa setup referring here https://www.intel.com/content/www/us/en/docs/programmable/683472/21-4/specifying-the-license-for-the-software.html
- Dor_ian
Thanks for reply.
I have Ubuntu 18.04.6 LTS so I think it's not supported refering to you table, but I installed Questa Starter edition which is not in it. So is it supported ?
If not, what can be the solution on this version of Ubuntu to have a complete simulation tool with Quartus 22.1.1 ?
Dorian
- Dor_ian
I checked the license.dat I have generated with SSLC and I found that there is just a INCREMENT field decommented and no FEATURE field as I found here : https://cdrdv2-public.intel.com/666293/quartus_install-683472-666293.pdf part 5.2.3.
I have just :
INCREMENT intelqsimstarter mgcld 2024.01 24-may-2024 uncounted \
Maybe that can explain the error I facing through.
When I try to regenerate a license file, I have now 2 INCREMENT field without FEATURE field.
It still doesn't work.
Dorian
- AR_A_Intel
We PM you another private message. Hope you received it.
- AR_A_Intel
We have not heard from you and I hope that my last note in private message mail clears up this matter and it can now be move forward. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
