bb9's avatar
bb9
3 years ago
license file for quartus II version 13.0.1 for old Stratix device (not stratix IV/V or 10)
I downloaded Quartus II ver 13.0.1 which I understand is the only currently available version that supports Stratix devices (not Stratix II/II/IV/V or 10). (The exact version is Quartus II 64-bit version 13.0.1 Build 232 16/12/2013 SJ Full version). I got this info from https://www.intel.com/content/www/us/en/support/programmable/support-resources/design-software/devices-support.html#intel%C2%AEstratix%C2%AEseries
I got the design to compile OK for Stratix, but it says it will not generate .sof file, since I was using an evaluation version. I can't make out whether this is a subscription/web/standard edition
So I went through the process of generating a license file and installing it, which went through. But now when I start Quartus it says "Stratix devices are not supported in this version of Quartus II web edition, use a version that supports your device". If I just go ahead, compile fails "Error (20005): A license file is required to enable compilation of your design for the Stratix family of devices". I could compile OK earlier.
It looks like the license file and the version I need for the Stratix device is not compatible. How to resolve such that I can compile and generate the programming file for the Stratix device?
  • AR_A_Intel's avatar
    AR_A_Intel
    Welcome to INTEL forum. Alternatively, could you apply an Intel 90-Day Evaluation License.
    Login to Intel® FPGA Self Service Licensing Center and request the Quartus evaluation free license here https://licensing.intel.com/
    1) Go to Sign up for Evaluation or Free licenses
    2) Select Intel® FPGA EVALUATION-LIC
    3) # of Seats is always 1
    4) Check the T&C box
    5) Add the required options
    6) Click Get License button
    The license will be sent to email that you register with
    AR_A_Intel
    We have not heard from you and It is not recommended to keep a Case idle too long without activities. I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
