17 years agowell, let me try to explain an example.
i tried to use the sieve of erastosthenes (http://en.wikipedia.org/wiki/sieve_of_eratosthenes) (http://en.wikipedia.org/wiki/sieve_of_eratosthenes) So i wrote this in verilog together with a counter. each second : - calculate next prime number - show number on 7-segment and it works fine, but the problem is that it does not scale. If i set the numbers to work on to be <15 i already need 18.000 logic elements but it works as it should. if i set it higher i need even much more elements.... But what i want : no matter how huge the numbers get, it should still work.
