8 years ago
LED to clock in Register
How to blink clock (CLK) in register?
Register code
module reg8 (CLK, D, Q);
input CLK;
input    D;
output   Q;
reg  Q;
always @(posedge CLK)
Q = D;
endmodule
Can i assign output LED = CLK?
output LED;
assign LED = CLK;
    --- Quote Start ---
    Can you just give information how FPGA, 555 & LED's are interfaced?
    --- Quote End ---
    i don't know. i just connect 555 to FPGA "clock" input pin.
    for example, https://www.youtube.com/watch?v=jl43vj6ksmo
    --- Quote Start ---
    --- Quote End ---
    OK, thanks
    --- Quote Start ---
    OK, thanks
    --- Quote End ---
    An issue then is what is the high/low swing of your 555 circuit output (ie, what Vcc are you running the 555 device at? 5.0V). The clock input of most all modern FPGAs will be limited to (probably) 3.3V or 2.5V at most, so apply 5V to the clock input could cause damage to the FPGA device unless the voltage and/or current is limited appropriately.
    ok, let's go back a bit, what are you trying to do? could you explain what yoh are trying to achieve?
    Why do you want to use the external oscilator?
    Hm-m-m-m. Now i want to know what PLL is? What is it? How does it work?
    In verry simple terms it is a clock frequency modulator. It can take one clock and output another at a higher or lower frequency,
