13 years ago
Launch to Latch Clock Timing (Slack Error)
I'm pretty new to TimeQuest Timing Analyzer and Constraining Nets, so any advice would be appreciated.
I have two clocks clk_50M (launch) and clk_125M (latch) that flags a slack error (-2.377). The data comes across the 50Mhz VME bus and clocked on the 125Mhz system clock to be used. Should I place a multicyle constraint on these nets?
--code sample
--write to selected register if reg_write is high
if reset = '1' then
data <= "0000";
elsif clk_50 = '1' and clk_50' event then
data <= VME_data(3 downto 0);
end if;
Thanks!
1 Reply
