19 years agoHi Raul,
You could have a compare between compile log, to see if there is any latch detected. I met the large timing discrepancy before, and I found the 7.1 detected much of the latch in the design while 6.0 not recognise it as latch. After I have fixed these latch, the timing change back common.So you could have a look of the warning message.
