19 years agoHi Raul
I doubt this is a bug, or an issue with the timing engine. I would expect you are seeing different syhthasis / fit results due to changes in the default settings for 7.1. It may be worth checking the LE useage you are seeing post Synth, and post map in 7.1 when compared to 6.1. I would expect something that was being optimised in 6.X is geting missed in 7.1 or implemented in LE's.
