i have a lot of time for division so is not an efficienty problem,
the problem, like in your approach, is that i have a 112 dividend and divisor and the substraction is slow.
i tried to do a multicycle
when en = 1 i do dividend - divisor
when en = 0 i do nothing
en change at half rate
these are the constraint
# Setup multicycle of 2 to enabled driven destination registers
set_multicycle_path 2 -to [get_fanouts [get_pins enable_reg|q*]
-through [get_pins -hierarchical *|*ena*]] -end -setup#Hold multicycle of 1 to enabled driven destination registers
set_multicycle_path 1 -to [get_fanouts [get_pins enable_reg|q*]
-through [get_pins -hierarchical *|*ena*]] -end –hold
