8 years ago"j" is not a constant in verilog for loop addition
I am trying to make a simple for loop to add up a parameterizable count of numbers, all in the same clock cycle( I am aware that this may not fit in a single cycle, I may split it up later to more cycles if timing issues arise.). What I am trying to do in essence is(for 3 numbers):always@(posedge clk) out=in+in+in; I am getting the error: "j is not a constant". I am sure there is a method to do this, am I trying to do this in a wrong way? My full code is: module mymodule# (
parameter maxIter = 9,
parameter bitCount = 16
input wire clk,
input wire in,
output reg out
initial begin
out=0;
end
integer j;
always@(posedge clk)begin
for (j=0; j<maxIter; j=j+1) begin
// I have tried this
// out= out + in;
// Then on a forum I found this
out= out + in;
// Neither works
end
end
endmodule
You want
out= out + in[bitCount*j +: 16]; - Altera_Forum
rozatib
Verilog specifies that if you are taking a slice, one of the indices must be a constant. - Altera_Forum
Thank you very much, problem solved.
