10 years agoIt is annoying the VHDL support in Quartus gets worse and worse
Why does the VHDL support from Altera keep getting worse? I keep bumping into IP generated VHDL files that that is just poorly made and in which case I have to use the Verilog generated files. ...
10 years ago) it is quite the same like situation with browser in old Windows OS. Why only Internet Explorer ?
in VHDL for test you can put assert operator, and making testbench in VHDL is also easy. perhaps it is compile time needed to verilog and VHDL program. I believe Verilog is more close to hardware architecture than VHDL in the manner it used. If you remember the time for compile or even only analysis and synthesis in MaxPlus and compare it with Quartus ... no comment I wonder if openCL program in C supersede Verilog. Just my opinion
