17 years agoHi rmc
Some thoughts for you: 1) I wouldn't use the variable that mmTsuchi suggested. Variables can be really useful but as various people have suggested they can catch you out if you're not careful. It will make no difference to your simulation or synthesis here - the synthesis process will strip it out anyway, so why bother! 2) Looking at your original code:
pr1: process(clk,reset,nombre)
begin
if reset='1' then
nombre<="0101010101";
else
if(rising_edge(clk)) then
nombre<=nombre+1;
else
nombre<=nombre;
end if;
end if;
end process pr1;
I would remove the last else - this is why you're getting the messages about the sensitivity list. Altera have some guidelines on coding for synthesis (which are pretty much the same as other FPGA manufacturers) - check out page 6-42: http://www.altera.com/literature/hb/qts/qts_qii51007.pdf?gsa_pos=1&wt.oss_r=1&wt.oss=coding%20style If I were you I would strip out the last else - it's not doing anything anyway:
pr1: process(clk,reset)
begin
if reset='1' then
elsif(rising_edge(clk)) then
nombre<=nombre+1;
end if;
end process pr1;
This is then exactly in line with Altera's coding guidance (and the other silicon manufacturers); there is no gratuitous code; it is simple and clear. Hope this helps Cheers batfink
