17 years ago --- Quote Start --- The warnings I have now are: Analysis & Synthesis: Warning (10492): VHDL Process Statement warning at prova1.vhd(39): signal "nombre" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Fitter: Warning: Feature LogicLock incremental compilation is not available with your current license Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details In EDA and in Simulations there are no errors nor warnings. I set reset 1 from the begining of simulation, during a clock period. then it remains 0 until the end. I generated the clock using the menu clock, as you've said. --- Quote End --- Hi rmc, it looks like that my reply is not received. In order to solve your problem, you have to remove the default value of your signal "nombre". After that it works fine with Quartus 8.0.
