17 years ago --- Quote Start --- The warnings I have now are: Analysis & Synthesis: Warning (10492): VHDL Process Statement warning at prova1.vhd(39): signal "nombre" is read inside the Process Statement but isn't in the Process Statement's sensitivity list Fitter: Warning: Feature LogicLock incremental compilation is not available with your current license Warning: Some pins have incomplete I/O assignments. Refer to the I/O Assignment Warnings report for details In EDA and in Simulations there are no errors nor warnings. I set reset 1 from the begining of simulation, during a clock period. then it remains 0 until the end. I generated the clock using the menu clock, as you've said. --- Quote End --- Hi Guy's when I remove the default value of the signal "nombre" all works fine. signal nombre : std_logic_vector(4 downto 0);
