DeusMMJr
8 years agoIssues with Partial reconfiguration.
Hi, i'm facing with issues relative to blinking_led partial reconfiguration example .sof recording. When i'm trying to program .rfb file, Programmer reports a error relative to access TIMEOUT and als...
DeusMMJr
8 years agoI tried to follow the document published in https://www.intel.com/content/www/us/en/programmable/documentation/ihj1482170009390.html
I have a special doubt about this tutorial. When, exactly, should I export root_partition_static.qdb?
Thanks a lot
JohnT (Intel)
May I know how do you implement your design using internal host? Is your data is being sent to the PR IP correct?
You can refer to https://fpgawiki.intel.com/
AN 797: Partially Reconfiguring a Design on Intel Arria 10 ...<https://www.intel.com/content/www/us/en/programmable/documentation/ihj1482170009390.html>
www.intel.com
Partial reconfiguration (PR) feature allows you to reconfigure a portion of the FPGA dynamically, while the remaining FPGA design continues to function. You can create multiple personas for a particular region in your design, without impacting operation in areas outside this region. This methodology ...
Deusdete Miranda Matos Junior
Processamento de Alto Desempenho
SENAI/CIMATEC
Sistema FIEB | www.fieb.org.br<http://www.fieb.org.br>
(71) 3462-8404
[email protected]
