Issues while compiling Quartus-pro-18.0.0.219 cyclone10gx components with Cadence NCSIM ?
I've been facing elaboration issues while compiling Cyclone10gx components from the below library in Linux.
Quartus-pro-18.0.0.219-linux-complete.tar
cyclone10gx_clk_phase_select_encrypted inst (
ncelab: *E,CUVMUR (/sim/tmp/dstdinge/intelFPGA_pro/18.0/quartus/eda/sim_lib/cyclone10gx_atoms.v,1892|46): instance 'cyclone10gx_clk_phase_select.inst' of design unit 'cyclone10gx_clk_phase_select_encrypted' is unresolved in 'worklib.cyclone10gx_clk_phase_select:v'.
ncelab: *E,CUVPOM: Port Name '{*Name Protected}' is invalid or has multiple connections.
I've seen the above messages during elaboration of library files.
Please help in finding a solution for this?
Mahesh,
- modur
I tried to compile with cds_lib files and the elaboration went smooth.
Thanks Musman for suggesting the tcl file creation.
regards,
Mahesh.
- MuhammadAr_U_Intel
Contributor
Hi Mahesh,
It seems like you are trying to simulate an Intel FPGA IP in NCSIM and facing some Error.
Can you confirm if you are using the AUTO GENERATED script to bring up the simulation ?
Which IP are you using, I can try to replicate and look into it ?
What version of NCSIM was used ?
Arslan
- modur
Hi Arslan,
I think you've got the problem.Below are the steps which i've performed in Quartus with NCSIM;
Step1: I opened Quartus Prime Pro 18.0 edition in GUI mode and ran EDA Simulation Library Compiler .
Please follow the attachment N0:1 for the list of options chosen by me.
Step2: Once i compiled the Library with target simulator NCSIM version 15.20, we can see cds.lib and
hdl.var and other log files in the target output directory.
Step3: From the above version of Quartus, I've downloaded the LVDS SERDES IP for compiling with
NCSIM.
Step4: I've flist_dut to compile the lvds files;
../../../../rtl/lvds_receiver_x8/altera_lvds_core20_180/synth/altera_lvds_core20.sv
../../../../rtl/lvds_receiver_x8/altera_lvds_core20_180/synth/altera_lvds_core20_pll.v ../../../../rtl/lvds_receiver_x8/altera_lvds_core20_180/synth/lvds_receiver_altera_lvds_core20_180_ze3vd7i.sv
../../../../rtl/lvds_receiver_x8/altera_lvds_180/synth/lvds_receiver_altera_lvds_180_6yosg6y.v
../../../../rtl/lvds_receiver_x8/synth/lvds_receiver.v
Step5: i've Makefile for NCSIM with below switches ;
irun -access rw $(INCLUDE) $(DEFINES) -ALLOWREDEFINITION -timescale 1ps/1ps -SVSEED ${SEED} -uvmhome $(UVM_HOME) -WORK work -CDSLIB ${CDS_LIB}/cds.lib -hdlvar /home/moduru/Documents/projects/Quartus_ncsim_lib/hdl.var -sv ....
Step6: After compiling; the NCSIM giving elaboration errors as below;
irun.log has shared....please follow the attachment.
- modur
Contributor
I have taken a look at your log file and the steps you described above.
To me it seems like problem is with your STEP4 you are using the file list from synthesis folder.
Solution 1:
Use the IP autogenerated script to bring up the simulation.
- Go to directory <ip name>/sim/cadence
- Execute ncsim_setup.sh
Solution 2:
- During the IP files generation make sure you generate simulation file, From IP Parameter Editor Window click Generate HDL > In the simulation tab change Create simulation Model from none to Verilog
- Use the IP file list documented under directroy <ip name>/sim/common/ncsim_files.tcl "proc get_design_files "
Let me know if this is helpful.
Arslan
- modur
I've successfully created the ncsim_files.tcl. But, couldn't run this tcl...
Can you please suggest me the command line option to run the ncsim_files.tcl?.
regards,
Mahesh
