JGoer1's avatar
JGoer1
6 years ago
Issues running Hello World openCL example missing libaltera_a10_ref_mmd.so
I'm trying to compile the hello_world openCL example. At first I was having an issue where it couldn't load the openCL platform. I got past that error by coping the $INTELFPGAOCLSDKROOT/Intel_FPGA_SSG_Emulator.icd file to /etc/OpenCL/vendors directory. Now when I go to run the host application, I get the following error:
bin/host: error while loading shared libraries: libaltera_a10_ref_mmd.so: cannot open shared object file: No such file or directory
I have updated my path to include $INTELFPGAOCLSDKROOT/bin, and set $LD_LIBRARY_PATH to $INTELFPGAOCLSDKROOT/host/linux64/lib.
Thanks for the help!
  • MEIYAN_L_Intel's avatar
    MEIYAN_L_Intel
    Can you try the command as below:
    CL_CONFIG_CPU_EMULATE_DEVICES=1 bin/host
    If the problem still persist, please tell me as well.
    • JGoer1's avatar
      JGoer1
      Hi Mylee,
      Apologies for the delayed response. I realized I was on an incompatible version of ubuntu, and have since install 16.04.
      However, after following the getting started pdf, I get a coredump from the hello world example
      $ bin/host
      Querying platform for info:
      CL_PLATFORM_NAME                         = Intel(R) FPGA SDK for OpenCL(TM)
      CL_PLATFORM_VENDOR                       = Intel(R) Corporation
      CL_PLATFORM_VERSION                      = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
      Querying device for info:
      CL_DEVICE_NAME                           = EmulatorDevice : Emulated Device
      CL_DEVICE_VENDOR                         = Intel(R) Corporation
      CL_DEVICE_VENDOR_ID                      = 4466
      CL_DEVICE_VERSION                        = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
      CL_DRIVER_VERSION                        = 19.3
      CL_DEVICE_ADDRESS_BITS                   = 64
      CL_DEVICE_AVAILABLE                      = true
      CL_DEVICE_ENDIAN_LITTLE                  = true
      CL_DEVICE_GLOBAL_MEM_CACHE_SIZE          = 32768
      CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE      = 0
      CL_DEVICE_GLOBAL_MEM_SIZE                = 16722680832
      CL_DEVICE_IMAGE_SUPPORT                  = false
      CL_DEVICE_LOCAL_MEM_SIZE                 = 16384
      CL_DEVICE_MAX_CLOCK_FREQUENCY            = 1000
      CL_DEVICE_MAX_COMPUTE_UNITS              = 1
      CL_DEVICE_MAX_CONSTANT_ARGS              = 8
      CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE       = 4180670208
      CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS       = 3
      CL_DEVICE_MEM_BASE_ADDR_ALIGN            = 8192
      CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE       = 1024
      CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR    = 4
      CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT   = 2
      CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT     = 1
      CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG    = 1
      CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT   = 1
      CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE  = 0
      Command queue out of order?              = true
      Command queue profiling enabled?         = true
      Using AOCX: hello_world.aocx
      terminate called after throwing an instance of 'std::bad_alloc'
        what():  std::bad_alloc
      Aborted (core dumped)
      Apologies for all the questions!
      • JGoer1's avatar
        JGoer1
        I just attempted to sanity check something, and recompiled both the aocx and the host binary, and I'm now getting the following output.
        $ ./host
        Context callback: Malformed program binary: missing .acl.board section
        Context callback: kernel argument info is not available
        Context callback: Invalid binary
        ERROR: CL_INVALID_BINARY
        Failed to create program with binary
  • MVALV2's avatar
    MVALV2
    I'm having the exact same issue. Where you able to fix this?
    Esteban VAlverde
    • JGoer1's avatar
      JGoer1
      The issue I had was I was on the wrong version of ubuntu. the fpga opencl sdk only support 16.04 and 14.04. The installation went smoothly after that, and now I'm getting a core dump in a hello world example.
    MEIYAN_L_Intel
    I would like to confirm the latest problem is regarding to the ERROR: CL_INVALID_BINARY or Aborted (core dumped)?
    • JGoer1's avatar
      JGoer1
      Hi there,
      Yes, my current issue is the ERROR: CL_INVALID_BINARY error.
      Thanks!
      • JGoer1's avatar
        JGoer1
        And just want to confirm the versions I'm using:
        Ubuntu: 16.04
        Intel FPGA OpenCL SDK: 19.3
    • JGoer1's avatar
      JGoer1
      I'm not looking to run on hardware right now, just get the emulator going. Getting a development kit is in future plans once I can get the SDK (namely the emulator) working. :) I did a aocl install with the provided a10_ref directory, otherwise I have done nothing with boards.
    MEIYAN_L_Intel
    It is the initialization and environment setup problem.
    I will need some time to test on the steps as in OpenCL Getting Started Guide.
    • JGoer1's avatar
      JGoer1
      Thank you so much for all of your time! Please let me know if I can provide any additional information you need. If there is some sort of live chat mechanism that makes this easier to get information from me faster, please let me know, and I'd be more than happy to accommodate a time to be available.
    • JGoer1's avatar
      JGoer1
      Hi Mylee,
      Is a licence for System Studio required to get this working? It looks like I didn't receive a licence for it, and going through the install steps notice that the intel "c compiler" won't work without it.
    • JGoer1's avatar
      JGoer1
      It appears to work as long as the -legacy-emulator option is specified. I can work with this for now, but if possible, I would like to use the default emulator.
      Thanks again for all your help!
    MEIYAN_L_Intel
    Sorry for late reply.
    I am still looking into it and try to duplicate the error.
    MEIYAN_L_Intel
    I am sorry for the late reply.
    According to https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/opencl-sdk/aocl_getting_started.pdf in Chapter 3.3, you set the environment variables transiently.
    Below is the script I had used to compile hello_world example with opencl offline compiler:
    export AOCL_BOARD_PACKAGE_ROOT=<opencl install path>/board/a10_ref
    cd $INTELFPGAOCLSDKROOT
    source init_opencl.sh
    cd <hello_world example path >/hello_world
    aoc -march=emulator -v device/hello_world.cl -o bin/hello_world.aocx
    cd hello_world && make
    CL_CONFIG_CPU_EMULATE_DEVICES=1 bin/host -n=10000
    Can you try the command?
    • JGoer1's avatar
      JGoer1
      Hi Mylee,
      I tried your commands, and I get the following output
      $ CL_CONFIG_CPU_EMULATE_DEVICES=1 bin/host -n=100000
      ERROR: CL_DEVICE_NOT_FOUND
      Query for number of devices failed
      When I try it with $ CL_CONTEXT_EMULATOR_DEVICE_INTELFPGA=1 bin/host -n=100000 I get the following output:
      CL_DEVICE_GLOBAL_MEM_SIZE                = 16722758656
      CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE       = 4180689664
    MEIYAN_L_Intel
    Could you provide me the environment variable for further investigate?
