JGoer1
6 years agoIssues running Hello World openCL example missing libaltera_a10_ref_mmd.so
I'm trying to compile the hello_world openCL example. At first I was having an issue where it couldn't load the openCL platform. I got past that error by coping the $INTELFPGAOCLSDKROOT/Intel_FPGA_SS...
JGoer1
6 years agoHi Mylee,
Apologies for the delayed response. I realized I was on an incompatible version of ubuntu, and have since install 16.04.
However, after following the getting started pdf, I get a coredump from the hello world example
$ bin/host
Querying platform for info:
CL_PLATFORM_NAME = Intel(R) FPGA SDK for OpenCL(TM)
CL_PLATFORM_VENDOR = Intel(R) Corporation
CL_PLATFORM_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
Querying device for info:
CL_DEVICE_NAME = EmulatorDevice : Emulated Device
CL_DEVICE_VENDOR = Intel(R) Corporation
CL_DEVICE_VENDOR_ID = 4466
CL_DEVICE_VERSION = OpenCL 1.0 Intel(R) FPGA SDK for OpenCL(TM), Version 19.3
CL_DRIVER_VERSION = 19.3
CL_DEVICE_ADDRESS_BITS = 64
CL_DEVICE_AVAILABLE = true
CL_DEVICE_ENDIAN_LITTLE = true
CL_DEVICE_GLOBAL_MEM_CACHE_SIZE = 32768
CL_DEVICE_GLOBAL_MEM_CACHELINE_SIZE = 0
CL_DEVICE_GLOBAL_MEM_SIZE = 16722680832
CL_DEVICE_IMAGE_SUPPORT = false
CL_DEVICE_LOCAL_MEM_SIZE = 16384
CL_DEVICE_MAX_CLOCK_FREQUENCY = 1000
CL_DEVICE_MAX_COMPUTE_UNITS = 1
CL_DEVICE_MAX_CONSTANT_ARGS = 8
CL_DEVICE_MAX_CONSTANT_BUFFER_SIZE = 4180670208
CL_DEVICE_MAX_WORK_ITEM_DIMENSIONS = 3
CL_DEVICE_MEM_BASE_ADDR_ALIGN = 8192
CL_DEVICE_MIN_DATA_TYPE_ALIGN_SIZE = 1024
CL_DEVICE_PREFERRED_VECTOR_WIDTH_CHAR = 4
CL_DEVICE_PREFERRED_VECTOR_WIDTH_SHORT = 2
CL_DEVICE_PREFERRED_VECTOR_WIDTH_INT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_LONG = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_FLOAT = 1
CL_DEVICE_PREFERRED_VECTOR_WIDTH_DOUBLE = 0
Command queue out of order? = true
Command queue profiling enabled? = true
Using AOCX: hello_world.aocx
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Aborted (core dumped)Apologies for all the questions!
JGoer1
6 years agoI just attempted to sanity check something, and recompiled both the aocx and the host binary, and I'm now getting the following output.
$ ./host
Context callback: Malformed program binary: missing .acl.board section
Context callback: kernel argument info is not available
Context callback: Invalid binary
ERROR: CL_INVALID_BINARY
Failed to create program with binary
