JDlug
6 years agoIssue with Quartus Prime PRO for Stratix 10 when using a string type in a VHDL project.
Hello, When using "Quartus Prime Pro 20.1" software with "Stratix 10" chip, I have a problem with VHDL string type in my projects. At the same time, I don't have this problem when using "Quartus Pri...
KhaiChein_Y_Intel
6 years agoHi,
Do you have any updates?
KhaiY
- JDlug6 years ago
Dear KhaiY, Thank you for your message and for remembering my problem.. but I'm not ready yet. :-( I am very sorry about this delay. I have so many different problems lately. I tried to prepare a code showing the issue but I didn't have enough time. We have the end of the semester here at the university and I have hundreds of students to whom I have to give grades. And because of coronavirus it is a crazy time. I'll prepare the code as soon as possible. As to the issue: Solving this Stratix_10 problem in Quartus Prime Pro is very important to me. In general, I think the problem appears when sharing string data between different entities. I need to prepare a short code showing this problem, but as I told you before, each compilation of the simplest code for Stratix_10 that I try to test takes me at least 9 minutes! which means: only seven tries take about an hour. This is not the case with another family of FPGAs (MAX10, Cyclon_IV and others). I promise that I'll do my best to prepare the code showing the issue as soon as possible. It is important for me because without your help in solving this problem, I can't and I won't be able to use my own IPs codes for the Stratix_10 chips. :-( Best Regards, (jd) - JDlug6 years ago
Hi, Motivated by your message here and your willingness to help, I spent the last night preparing a code showing the problem. I enclose it at the end of this message. The code doesn't make any sense, but it's rather compliant with the VHDL standard and compiles correctly for MAX10 and Cyclone_IV FPGA chips. But when I choose Stratix 10 (and also Cyclone 10, which I discovered yesterday) Quartus Prime shows errors. if there is: set_global_assignment -name ENABLE_STATE_MACHINE_INFERENCE ON I get exception error: "Sorry! The Quartus Prime software quit unexpectedly." if there is: set_global_assignment -name ENABLE_STATE_MACHINE_INFERENCE OFF I get processing errors: Error(13076): The node "instance_1|str_1[1][0]" has multiple drivers. Error(20073): "constant GND" is one of the multiple drivers. Error(20073): "non-tri-state driver "str_1[1][0]"" is one of the multiple drivers. Error(13076): The node "instance_1|str_1[1][1]" has multiple drivers. Error(20073): "constant GND" is one of the multiple drivers. Error(20073): "non-tri-state driver "str_1[1][1]"" is one of the multiple drivers. Error(13076): The node "instance_1|str_1[1][2]" has multiple drivers. Error(20073): "constant GND" is one of the multiple drivers. Error(20073): "non-tri-state driver "str_1[1][2]"" is one of the multiple drivers. Error(13076): The node "instance_1|str_1[1][3]" has multiple drivers. Error(20073): "constant GND" is one of the multiple drivers. Error(20073): "non-tri-state driver "str_1[1][3]"" is one of the multiple drivers. Error: Failed to synthesize partition As you can see, the errors say that "str_1" has multiple drivers but there is only one explicit place where "str_1" is driven. The command: str_1:="ABCD";. These errors disappear when you do a tiny change in the code. For example, they dissappear when you comment the line "data<=vec_1(3 downto 0);". It makes no sense to me because this line does nothing with "str_1"! The errors also disappear when you change: if s2/=s1 then s2:=s1; str_1:="ABCD"; end if; to only: str_1:="ABCD"; which is completely strange to me, but I understand that the driver here becomes stronger then. Of course, the errors also disappear after changing the direction "inout" to "in" for "str_1" in entity "e2", but in my operative code I need bidirectional "str_1", and with this "inout" everything works fine for MAX10 and Cyclone_IV. And why did Quartus Prime put the GND driver in the "e2" entity, if it leads to an obvious drivers conflict? I hope that below code will help you find the cause and then create a fix. Here is the code with two entities: ########################################################### - JDlug6 years ago
Something has cut the code, so here it is again: ########################################################### library IEEE; use IEEE.STD_LOGIC_1164.all; use IEEE.STD_LOGIC_ARITH.all; entity e1 is port( data : out std_logic_vector(3 downto 0); clk : in std_logic ); end e1; architecture arch1 of e1 is component e2 is port( data : out std_logic_vector(3 downto 0); clk : in std_logic; str_1 : inout string(1 to 4); vec_1 : inout std_logic_vector(31 downto 0) ); end component; shared variable str_1 : string(1 to 4); shared variable vec_1 : std_logic_vector(31 downto 0); shared variable s1, s2 : std_logic; begin instance_1 : e2 PORT MAP ( data => data, clk => clk, str_1 => str_1, vec_1 => vec_1 ); process begin wait until clk'EVENT and clk='1'; s1 := not s2; end process; process begin wait until clk'EVENT and clk='1'; if s2/=s1 then s2:=s1; str_1:="ABCD"; end if; vec_1(7 downto 0):= conv_std_logic_vector(character'pos(str_1(1)),8); end process; end arch1; library IEEE; use IEEE.STD_LOGIC_1164.all; entity e2 is port( data : out std_logic_vector(3 downto 0); clk : in std_logic; str_1: inout string(1 to 4); vec_1: inout std_logic_vector(31 downto 0) ); end e2 ; architecture arch1 of e2 is begin process variable clk2: std_logic; begin wait until clk'EVENT and clk='1'; data<=vec_1(3 downto 0); clk2:= not clk2; end process; end arch1; ########################################################### Best Regards, (jd) - JDlug6 years ago
Hi KhaiY, I attach the files you requested. Best Regards, (jd)
